Activity Forums Apple Final Cut Pro Legacy stepping and de-interlacing
  • stepping and de-interlacing
    Posted by Peter Hall on November 3, 2011 at 8:02 am
    I am editing some old NTSC DV footage for the first time on FCP7, I am seeing some stepping on hard/contrasty horizontal surfaces which I don’t remember seeing from my old NLE. This seems to change depending on what size I set my viewer, but the stepping is most evident when I view full frame (Digital Cinema Desktop Preview) on my MBP. I don’t have a proper monitor. I have tried the default Apple De-Interlace effect (upper odd) and it seems to take the edge off, at the cost of considerably softening the entire image. I wonder if this is the best solution. I also wonder if I have imported the footage correctly (DV NTSC 48Khz) in the first place, not having noticed the stepping before on other non-linear editors?
    I greatly appreciate any light that anyone can shed on this problem.
    Peter Hall replied 14 years, 10 months ago 3 Members · 4 Replies
  • Rafael Amador
    November 3, 2011 at 9:02 am
    [Peter Hall] “his seems to change depending on what size I set my viewer,”
    That’s the proper way of setting the window.
    [Peter Hall] ” I have tried the default Apple De-Interlace effect (upper odd) and it seems to take the edge off, at the cost of considerably softening the entire image.”
    DV is LOWER FIRST.
    The default de-interlacer is not a good filter. You can try Revision FieldsKit or, the Nattress deinterlacers or JES de-interlacer (stand alone),.
    Rafael
    http://www.nagavideo.com
  • Peter Hall
    November 3, 2011 at 9:28 am
    Thanks Rafael, the sequence is set to lower (even) dominance, but the default de-interlacer only removes the stepping when it is set to upper (odd). I agree it is probably not very good but it is better than Stibs and TMTS de-interlacers I have already installed. I shall look into those products you suggested. Thanks for coming through, once again!
    Peter Hall
  • Chris Tompkins
    November 3, 2011 at 12:00 pm
    If your footage is interlaced it will not look good on a computer screen as they only display progressive.
    Don’t deinterlace that DV footage if going to DVD.
    Deinterlace it when you create a delivery for web or comp. screen.
    Chris Tompkins
    Video Atlanta LLC
  • Peter Hall
    November 3, 2011 at 4:51 pm
    Thanks Chris, valuable points, well noted. Looks like I’ll have to make different versions applying de-interlace in the few clips that need it. Mostly it will be for Youtube/Vimeo or QT file distribution. Much obliged for your info.
    Peter Hall
