Activity › Forums › Avid Media Composer › Step In/Step Out
Step In/Step Out
Posted by Cbarnett on August 15, 2007 at 5:34 pmCan someone tell me how to “Step in” to a video line to add multiple effects…
I’ve read there is a key for it on the keyboard… but I have no idea which if it is actually there…
thanks!
=cb
Joe Womble replied 19 years ago 3 Members · 2 Replies -
Leisa Bolles
August 15, 2007 at 7:42 pmTo step in you can use the down arrow in the bottom left corner of your timeline. You can also map it to your keyboard using your command palette. Stepping in this way will allow you to see only one layer of the nest at a time which is useful if you need to isolate a specific layer for manipulation(simple nesting.) However, if you need to see it as a composite you can use the alt/opt key with the step in arrow and it will show the nest in expanded form. You can also double click the effected clip in the timeline if you are in effect mode or segment mode and that will reveal the expanded nest. To close or collapse the expanded nest you merely have to double click the bottom most layer of the composite. If you use the alt/opt key with the step in arrow you need to use the alt/opt key with the step out arrow to close it.
Joe Womble
August 15, 2007 at 7:42 pmSure, dude.
It’s the up(Step Out) and down(Step In) arrows at the bottom left of your timeline. It’s for if you already have multiple or nested effects.
Add another effect by holding down Alt and dragging a second effect onto the shot with the first effect.
Regards,
Joe Womble
