Activity › Forums › Adobe Premiere Pro › Step forward field by field in CS6?
  • Step forward field by field in CS6?
    Posted by Kell Smith on March 20, 2018 at 10:51 pm
    I just want to check the field motion step pattern on some clips. In the monitor you can show both fields, but is it possible to step field by field? I’m on CS6.
    Kell Smith replied 8 years, 6 months ago 2 Members · 2 Replies
  • Pat Horridge
    March 21, 2018 at 7:02 am
    I don’t think there is a field step command like Avid.
    You can change which field is displayed. So you can toggle field.
    But it’s a bit of a dance to check a series of frames.
    You end up looking at field one toggling to field 2. Step forward one frame (but you now looking at field 2 still so you have to toggle back to field one then toggle to field 2) then repeat.
    Pat Horridge
    Broadcast & Post Consultant, Trainer, Avid Certified Instructor
    Free online Tutorials at VET digital media academy online https://vimeo.com/channels/752951
    pat@vet.co.uk
  • Kell Smith
    March 21, 2018 at 11:38 am
    Ok thank you!
