Activity Forums Maxon Cinema 4D Step effector with fracture object and vector paths
  • Step effector with fracture object and vector paths
    Posted by Steve Renard on August 18, 2016 at 1:46 pm
    Greetings all – apologies if this is a newbie question but this one has me really confused. I brought piece of vector art into C4D as a .ai file (version 8), dropped those paths into an Extrude, then dropped the Extrude into a Fracture object so that I could use a step effector to have all the elements fall into place sequentially. However, it seems that no matter what I do, some of the elements end up out of order for the step effector as in this image:
    Here’s the general setup of my project:
    I have the extrude objects set to “hierarchical”, otherwise the paths in each null object aren’t recognized. Would that do something weird to the order? If I change the order of the paths, it seems to change how each letter is affected by the effector, but there doesn’t seem to be much rhyme or reason to it.
    Any thoughts or suggestions are most welcome. Thank you in advance!
    Steve Renard replied 10 years ago 2 Members · 2 Replies
  • Brian Jones
    August 18, 2016 at 2:50 pm
    we’re not seeing enough since we can’t see if each letter is it’s own spline or whole words but either way it’s probably easier to use a Plain effector with a linear falloff instead and animate that through the text.
  • Steve Renard
    August 18, 2016 at 3:01 pm
    That seems to work, along with pulling the various elements apart into their own extrude objects. Thanks!
    Steve Renard
    647-406-7991
    steve@steverenard.com
