Activity Forums Avid Media Composer Step by step should you get the dreaded “error has occurred restart your comp” promp
  • Step by step should you get the dreaded “error has occurred restart your comp” promp
    Posted by David Powell on January 6, 2012 at 6:36 am
    First open all your bins. This worked the first time. I don’t know why but it did. If it doesn’t, try go to your avid media folder and delete the database files start up MC and it will rebuild. If that doesn’t work, go to the the timeline hamburger menu, click “clip color” and select “color offline clips”. Find the clips that are offline, reimport them and recut them into your clips. Hopefully you know what the cut was supposed to look like.
    This will solve the problem. For some reason “relink” never freakin works when a clip goes offline for me.
    Hope this saves someone a few hours.
    David Powell replied 14 years, 7 months ago 2 Members · 2 Replies
  • Scott Cumbo
    January 6, 2012 at 1:43 pm
    just batch import stuff if it goes offline, though things going offline is rare in my experiance
    Scott Cumbo
    Editor
    Broadway Video, NYC
  • David Powell
    January 6, 2012 at 6:25 pm
    I believe the media had become corrupted.
