Activity › Forums › Apple Final Cut Pro Legacy › Step-By-Step Guide after FCS2 Template/SFX Install onto other drive
  • Step-By-Step Guide after FCS2 Template/SFX Install onto other drive
    Posted by Pat Defilippo on July 26, 2007 at 5:44 pm
    Hello,
    I bought a Lacie 100GB “Rugged” drive because it is bus powered, 7200rpm (fast enough to reliably edit on), has FW800/FW400/USB2.0, fits easily into my computer bag and was available at the lowest cost that I could find (I’m a bit slower work wise this summer, so this part is particularly important)!
    The biggest reason I bought it, though, wasn’t necessarily for any of the above. It is mainly to take advantage of FCS2’s new feature of installing templates, sound effects, etc., onto a drive other than the startup. The biggest benefit is to save at least 25GB of internal hard drive space, which is especially great for my MacBook Pro – but I also installed FCS2 this way onto my G5 Quad. Then, I can use the same external drive on either system as needed – just plug and play!
    After installing the templates, sound effects, etc. onto the Lacie, which is pretty easy to re-map to during the FCS2 installation process, a problem occurred. The FCS programs (namely STP, DVDSP, Motion and LiveType) are still “looking” in the default installation location for these templates, etc., and, of course, not finding them.
    I looked for information online about how to correct or change this, but could not find it. So, I figured it out myself and, below, I’m sharing this step-by-step info with anyone who needs it. If you install templates, etc., to another drive, I hope the following info will help you access them in your FCS programs:
    FIRST AND FOREMOST – name this other drive the name you want to live with (which, below, I refer to as “your other drive” – in my case, I call it “Lacie Rugged”). This is critical to do now because every time you change the name of the drive in the future, you’ll have to re-do all of the following steps.
    SECOND – make a folder called
    Pat Defilippo replied 19 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
