Activity › Forums › Boris FX Particle Illusion › stenciling particles, why is it in reverse?
  • stenciling particles, why is it in reverse?
    Posted by Jclarke on October 7, 2006 at 2:15 am
    Can anyone explain why when i tick “Use image as stencil” in the transparency panel, then go back to the timeline and place an area emmiter over the video, it puts the emitter everywhere but the character that I bluescreened?
    Can anyone explain how to reverse this?
    Aharon Rabinowitz replied 19 years, 11 months ago 3 Members · 3 Replies
  • Alan Lorence
    October 7, 2006 at 12:11 pm
    Is Stencil the feature you want to use, or is “Area Emitter Mask” the feature you want? They’re similar, but Stencil draws the particles, then draws the stencil image over it, so particles only show where the transparent parts are. Think of it as laying a physical stencil sheet over a drawing — you only see the parts of the drawing where there are holes in the stencil.
    Area Emitter Masks control where particles are created (doesn’t clip particles like the “stencil” option does), and only creates particles in the non-transparent areas of the alpha channel.
    Alan.
    wondertouch
  • Jclarke
    October 7, 2006 at 12:15 pm
    Thanks Alan,
    I didn’t know the differance,
    That helped a lot
  • Aharon Rabinowitz
    October 10, 2006 at 3:37 am
    If you want to learn the real ins and outs of pillusion – check out Elvis Deane’s particleIllusion DVD: https://www.creativecowtraining.net
    It goes through virtually all of the features found in pillusion.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
