Activity › Forums › Maxon Cinema 4D › Stencil or Drill Spline/Path into a Polygon Object???
  • Stencil or Drill Spline/Path into a Polygon Object???
    Posted by Justin Vennes on October 27, 2009 at 10:51 pm
    Hello all,
    Cinema 4D V11.
    I’m going to try and explain this as best I can but forgive me it this sounds confusing. Let’s say I have a box polygon and I want to take a circle path and “Stencil” or “Drill” the shape of the circle into the box so that I can then recess/inner-extrude the circle into the box. Wondering if there is a simple way to handle this modeling task? Kind of like the power button on your television set. When you push the button it recedes into the box. I have a little Lightwave experience and this was fairly simple.
    Thanks in advance.
    Justin Vennes replied 16 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
