Activity Forums Adobe After Effects steep of a curve to drive the color of a dot
  • steep of a curve to drive the color of a dot
    Posted by George Matthew on December 9, 2008 at 2:20 pm
    I have a blip animating along a curve. (A graph)
    The x axis of the graph has a pointer shape that gets its position[0] from the position[0] of the blip moving along the curve. What should I play around with in javascript to get an effect so that the pointer changes its color proportionately to the speed at which it moves?
    George Matthew replied 17 years, 9 months ago 2 Members · 2 Replies
  • Dan Ebberts
    December 9, 2008 at 3:11 pm
    You could add a fill effect to the pointer with an expression like this for the fill color:
    zeroSpeedColor = [1,0,0,1]; // red
    maxSpeedColor = [1,1,0,1]; // yellow
    maxSpeed = 500; // pixels per second
    linear(transform.position.speed/maxSpeed,0,1,zeroSpeedColor,maxSpeedColor)
    You’d need to adjust the colors and maxSpeed to suit your needs.
    Dan
  • George Matthew
    December 9, 2008 at 3:47 pm
    Thank you so much
