Activity › Forums › Adobe Premiere Pro › steady with quality
  • steady with quality
    Posted by Gonzalo on November 25, 2005 at 2:02 am
    hello all
    is there a way to use the steady filter without loosing quality in the render
    ive tried different set ups and all seem to reduce the quality of the movie
    thanks
    Bob Cole replied 20 years, 10 months ago 5 Members · 5 Replies
  • R. Hewitt
    November 25, 2005 at 1:18 pm
    They always will reduce quality.
    The filter is trying to create new frames of media based on shakey versions – something has to give and that is the quality.
  • Gonzalo
    November 25, 2005 at 2:45 pm
    thanks very much R. Hewitt
    gonzalo
  • Steven L. gotz
    November 25, 2005 at 7:57 pm
    Generally, just imagine that the steadymove utility zooms in so that the edges don’t show as it adjusts an area in each frame to be in the same place instead moving around. It is the zoom that causes the loss.
    Steven
    Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Kevin Lee
    November 26, 2005 at 7:24 pm
    just wondering if applying some sharpness might help? it will look digitally enhanced but may help…
  • Bob Cole
    November 27, 2005 at 9:51 pm
    [Steven L. Gotz] “It is the zoom that causes the loss.”
    true; and so an option would be to reframe the sequence with a black border. You might also get points for “creativity;” I suspect many a “creative” black-and-white scene originated as a scene with the wrong color balance.
