Activity Forums Event Videographers SteadiShot Pro 6000
  • SteadiShot Pro 6000
    Posted by Michael Murray on October 8, 2008 at 2:41 am
    Has any one had any experience with Image Wests SteadiShot Pro 6000 Camera Stabilizer? They state that it works just like a SteadiCam at a fracton of the cost.
    Anyone?
    Michael Murray
    Summer Wind Productions
    Rick Wise replied 17 years, 11 months ago 4 Members · 4 Replies
  • Bouncing Account needs new email address
    October 8, 2008 at 11:46 am
    [Michael Murray] “They state that it works just like a SteadiCam at a fracton of the cost. “
    Don’t they ALL say that?
  • Michael Murray
    October 8, 2008 at 6:54 pm
    Probably, I just can’t afford Steadicam. Has anyone had any luck with any other brands that are under $3000.00?
    Michael Murray
  • Beau Brotherton
    October 15, 2008 at 5:02 am
    I’m not a steadicam operator, but I am in the same boat as you are. I am looking for a quality rig for a lower price.
    What I have found from my research is that it is more depending on how much weight you are planning on flying. By this, what camera do you have. If you are shorting primarily weddings, I assume you use your own cameras and don’t use a wide range of cameras.
    With this info, you can pick a real Tiffen Steadicam rig to match your camera.
    Merlin: up to 5 lbs less than $4000 w/ vest and arm
    Pilot: 5 – 10 lbs less than $6000
    Flyer LE: 10 – 19 lbs? less than $9000
    If you are doing mainly events videography (since you are in the Event forum) I don’t see you needing anything bigger than the Flyer. Especially if you are a beginner, you don’t want to invest anything more than that.
    Although, if you are wanting to freelance as a steadicam operator for my commercial work, you would want to go w/ the Flyer at a minimum. And if you are wanting to be taken series, you want to only work with Steadicam, it is by far the best quality. Everything else is just a knock off of Steadicam.
    Good luck and let us know what you go with.
    Beau Brotherton
    Macbook Pro 2.4GHz, Intel Core 2Duo, 4GB
    FCP6
    HVX200
  • Rick Wise
    October 15, 2008 at 4:38 pm
    Actually the complete Merlin is a lot less than $4,000; it’s about $2,500 at B&H and probably elsewhere. https://www.bhphotovideo.com/c/product/493331-REG/Steadicam__Merlin_Camera_Stabilizing_System.html#features
    Or, you can go with just the gimbal part for $800, though your forearm will get tired very, very quickly with any camera over 1 lb in weight.
    Rick Wise
    director of photography
    Oakland, CA
    http://www.RickWiseDP.com
    email: Rick@RickWiseDP.com
