Activity Forums Cinematography Steadicam Recommendations
  • Steadicam Recommendations
    Posted by Doug Hodgson on March 10, 2006 at 7:59 pm
    My addiction to gear is continuing. After picking up an EZ FX Jib Arm for my Betacam, I’m now contemplating a Steadicam Rig. Haven’t used one on a shoot in awhile but may be required to use one continuously in the future for a gig.
    Anybody have any recommendations on vendors?
    I’m 2 for 2 in asking so far, having had great success with a Teleprompter referral to Prompter People and the Jib from EZ FX. Thanks again in making my projects look better and better.
    Hodge
    Steve Freebairn replied 20 years, 5 months ago 4 Members · 5 Replies
  • Bob Woodhead
    March 11, 2006 at 3:11 pm
    Since the weight of your rig will necessitate one of the larger Steadicams, perhaps you should give the used market a look? The tech in Steadicam doesn’t change radically from year to year, so maybe you can find a deal from a shooter with a bad back. Check out BCS & the Greene Sheet.
  • Doug Hodgson
    March 14, 2006 at 5:21 pm
    Thanks Bob, I’ll do that.
    Hodge
  • Sydneys
    March 20, 2006 at 3:04 am
    I actually don’t recommend used steadicam gear, mostly because of the vest… After time, it sort of becomes a living part of the operator… Also, the market for large rigs is extremely small, so typically the depreciation is very low… Considering new, and for a betacam size rig, you can go relatively inexpensively to Varizooms site, ($4,000-$8000) or Glidecams site, (Around $8,000 and up) There are other companies that make mid range rigs, but the ones I mentioned are the most well known, when not including the high end rigs, ($75,000 and up)
  • Doug Hodgson
    March 21, 2006 at 11:00 pm
    Thanks Sydney, the Blackhawk Model from Varizoom looks pretty good @ 6K.
  • Steve Freebairn
    April 10, 2006 at 5:35 pm
    I’m a Glidecam fan myself. I think (and it’s just an oppinion) that Glidecam is better than varizoom. There products don’t seem as professional.
