Activity › Forums › Apple Final Cut Pro Legacy › Std def, Film Effects and LCD monitors
Posted by Slim Simon on February 15, 2006 at 2:27 pmFolks,
I took some std def footage in FCP, and added the Nattress Film effect. Very basic 3:2 pulldown. I played it back on a regular NTSC monitor, and it looked fine. Footage was played back on digibeta, and DVD. When I walked it down the hall to show the boss, we watched on his new Sharp Aquos 45in. LCD HDTV, and it looked horrible. Lots of aliasing, and visible interlacing.
What do I need to do to make std def footage look good on LCD televisions? Any help would be appreciated.Thanks,
Slim
David Roth weiss replied 20 years, 7 months ago 6 Members · 9 Replies -
Bouncing Account needs new email address
February 15, 2006 at 3:07 pmSD can look absolutely TERRIBLE on an HDTV LCD monitor.
If you want to know how SD “actually” looks… a good CRT is still the way.
Slim Simon
February 15, 2006 at 3:30 pmRight, but is there a way to prep the SD footage so it looks better on an LCD?
Mark Maness
February 15, 2006 at 3:44 pmI’m sorry but your only hope is that you can watch it on a standard def LCD monitor. HD LCD monitors only magnify the problems of standard def video. It will show you your compression very very well. And no, rendering to uncompressed isn’t going to make it better. Sorry! I have those same issues at my facility.
_______________________________
Wayne Carey
Schazam Productions -
David Roth weiss
February 15, 2006 at 4:51 pmSlim,
Go into the menu on the LCD TV and see if you can turn “auto scaling” off. The TVs scaling engine is uprezing from 480i to 720i or 1080i and doing a lousy job. If you can turn it off you will probably see a dramatic improvement. Most, but not all TVs have a toggle allowing internal scaling to be switched off.
DRW
Don Greening
February 15, 2006 at 6:33 pmDavid,
Would an LCD television’s auto-scale toggle be known as anything else? I would like to try your recommendation on my own BenQ 26″ but I can’t see anything in the on-screen menus that looks similar.
– Don
David Roth weiss
February 15, 2006 at 6:57 pmDon,
Unfortunately all TVs are not created equal. Some have this feature in easliy accessible places in the menu, others bury it in the factory level settings that have to be adddressed with secret codes. I’d contact the manufacturer.
DRW
Sean Oneil
February 15, 2006 at 7:02 pm[slim] “I took some std def footage in FCP, and added the Nattress Film effect. Very basic 3:2 pulldown. I played it back on a regular NTSC monitor, and it looked fine. Footage was played back on digibeta, and DVD. When I walked it down the hall to show the boss, we watched on his new Sharp Aquos 45in. LCD HDTV, and it looked horrible. Lots of aliasing, and visible interlacing.”
If “jaggies” are the problem, the problem has nothing to do with scaling. Whether it’s on an SD or HD LCD makes no difference. In fact, there’s no such thing as a SD LCD. Standard def is interlaced, non-square pixels. LCDs are always progressive scan, square pixels. If this is film based footage, what’s possiby happening is that your cadence is off, so the monitor can’t figure out how to deinterlace it.
But if this is video-based 30fps footage, and you’re trying to make it look like film, I think what you want to do after you apply the Natress effect is to place it on a 24p timeline. Then export the sequence as a self-contained 24p Quicktime file. Then import that file, place it on a 60i NTSC timeline, render it, and output to digibeta.
Don Greening
February 15, 2006 at 7:58 pmThanks, David. Insightful as usual. I’ll contact BenQ.
– Don
David Roth weiss
February 15, 2006 at 11:17 pm[Sean ONeil] “In fact, there’s no such thing as a SD LCD.”
What would you call one of the many 4×3 LCD TVs on the market that only display stand definition???
