Activity Forums Adobe After Effects Expressions Statistics Graph Expression Problem
  • Statistics Graph Expression Problem
    Posted by Mamuka Kavtelishvili on July 19, 2013 at 9:00 am
    Hello again, as i said in my first thread, i’m working on television projects, so now i need to create statistics graphs with values. i’ve used some expressions to make it easy with just one control layer, but i have a problem. problem is that i want to write the number in control layer and value position and graph position must be the same, but it comes that value has different space from graph layer on each percent. check this out:
    can anybody tell me how to fix this? here’s the test project file to download. thank you 🙂
    6279_graph.aep.zip
    Mitch Mann replied 13 years, 2 months ago 2 Members · 1 Reply
  • Mitch Mann
    July 19, 2013 at 2:45 pm
    Here’s how I would do it: Rather than trying to get the math elegant and perfect, just add a slider to each one. You can then add the slider’s value to the Y value of the number position, and adjust it for each bar’s number. This could also be convenient if you have a background image and you want to nudge one of the numbers up or down to not interfere with the background.
