Activity Forums Adobe Premiere Pro station says HD Op1 mxf captioning data is incorrect
  • station says HD Op1 mxf captioning data is incorrect
    Posted by Chris Borjis on August 12, 2016 at 12:07 am
    A station I sent an .mxf to, that has embedded captions exported from premiere cc 2015
    say that the metadata is incorrect and thus preventing the captions from displaying.
    In media info, the problem file is identifying the caption stream as: “Ancillary data”
    when it should be showing as: “DTVCC Transport”
    Not seeing any option to change that in premiere…any ideas?
    Josh Nikon replied 6 years, 5 months ago 2 Members · 2 Replies
  • Chris Borjis
    August 15, 2016 at 6:02 pm
    Thanks for the suggestion Dave.
    Nothing in there I can change but the service stream number.
    grr.
    The help file for premiere says you can export a quicktime with embedded captions,
    but it doesn’t work when I specify embedded captions on export.
  • Josh Nikon
    April 15, 2020 at 12:19 am
    Did you ever figure this out.. having the same issue.
