Activity › Forums › Apple Final Cut Pro Legacy › Static Audio when monitored through Firewire
  • Static Audio when monitored through Firewire
    Posted by The_tick on July 16, 2007 at 7:29 am
    Hello,
    I am having a weird problem when monitoring audio out of a Panasonic DVCPro AJ-1400
    via Firewire. The audio sounds “Staticy” it sounds fine when monitored via SDI however.
    I have tried multiple setups with different Laptops, Decks, Cables, clips shot on different cameras. Footage has come from multiple HDX-900s
    anyone have any idea what might cause this?
    The_tick replied 19 years, 2 months ago 2 Members · 4 Replies
  • Jerry Hofmann
    July 16, 2007 at 2:07 pm
    Bad cable? FW bus power needing resetting via a PMU button?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • The_tick
    July 16, 2007 at 3:42 pm
    Thanks Jerry,
    I checked all of that, it is a problem a team in the field is having, and like I said they have tried multiple laptops / Decks / Cables / Cameras, you name it they tried it swapping it out.
    I tried it back in the studio and recieved the same results with a Tower and a laptop, again different decks cables etc…
    my only thought is it has something to do with how the audio is being recorded.
    any other ideas?
  • Jerry Hofmann
    July 16, 2007 at 8:59 pm
    Might be something about how the audio is recorded alright, maybe the camera(s) or the deck need a touch of calibration or something. If you reset the PMU and you know that the cable is fine, and the deck works OK otherwise, it’s likely something else which points at the camera’s recordings.
    Is it all tapes or do you have some that seem to work OK?
    Jerry
  • The_tick
    July 17, 2007 at 2:38 am
    yeah everything I have tested seems to point to how it was recorded, my research says FCP used to (possibly still does) have issues playing back 12bit audio over Firewire,
    however I believe the HDX-900 natively records at 16bit ( I am not a camera guy) any other ideas?
