startup problem
Hi-
I have a powerbook G4, used daily by students in a television class.
The laptop, when starting, shows us a screen that says “You need to restart your computer. Hold down the power button for several seconds or press the restart button”. It shows the message in several languages.
I started the computer with the install disk, went to disk utilities, and tried repairing permissions and repairing the disk. It said everything was okay. Restart-same problem.
I did a complete reinstall of the system software. When it restarted after the first disk, same problem.
I then restarted in the safe mode, using the shift key. It then asked for the second install disk. After the installation was finished, I tried restarting the computer. Same problem.
Any ideas about where to go from here?
Thanks very much.
Craig Lindvahl
