Activity Forums Apple OS X Startup disk problem
  • Startup disk problem
    Posted by Mozuringo on April 6, 2006 at 10:54 pm
    When I was using FCP, it freeze so I turned off and on the computer but it started with external disk. I couldn’t see HD in the startup disk. How can I startup with original HD? Thanks.
    Simon Carlson-thies replied 20 years, 5 months ago 2 Members · 2 Replies
  • Mozuringo
    April 6, 2006 at 11:03 pm
    And also, when I tried disk utility, it checked only external HD… Why it is happening? I didn’t change the startup disk setting. Please help!!! Thank you.
  • Simon Carlson-thies
    April 9, 2006 at 6:53 pm
    try turning off the external drive a see if that forces the computer to start off the internal HD. If not try running disc utility after booting up off the CD, and make sure you keep the external drive off.
    Best of Luck
    Simon Carlson-Thies
    Simon Carlson-Thies,
    Digital Light Graphics And Animation
