Starting to Panic: Vegas Not Rendering!
Edan Cohen replied 16 years, 6 months ago 6 Members · 15 Replies
Edan Cohen
March 25, 2010 at 10:53 pmI still haven’t outputted an HD version. If I buy epic plugin, will I need to re-edit my entire project? If so, what is the process if I’m able use an edl? I can’t start from scratch, I’ll have a heart attack.
Marcus Van bavel
March 26, 2010 at 7:52 am[Edan Cohen] “I still haven’t outputted an HD version. If I buy epic plugin, will I need to re-edit my entire project? If so, what is the process if I’m able use an edl? I can’t start from scratch, I’ll have a heart attack.”
No, you can import a pre-existing project of H.264 quicktime files into Vegas 9/32 using Epic I. Before you try that with the Epic demo however, I would make a backup copy of your project. In fact it would probably be better to try Epic I with a test project first.
The demo is at https://dvfilm.com/epic
Edan Cohen
March 26, 2010 at 12:48 pmI edited the current project with Vegas 9 x64. So, I would need to install Vegas 9 x32, then Epic. So far so good.
Does anyone know if an x64 project will open in x32 Vegas?
If yes, then you are telling me I may be able to use my previously saved project with Epic??
That would be EPIC, indeed.
Chris Young
March 26, 2010 at 1:59 pmTruly EPIC! Yes you can open a v9.0 64-bit in 9 32-bit.
Chris Young
CYV Productions
Sydney -
Edan Cohen
March 26, 2010 at 2:01 pmThanks, Chris — and to all of you.
If I ever get an HD render of this video, I will owe all of you a drink.
