Activity Forums Adobe After Effects Expressions Starting / stopping expressions
  • Starting / stopping expressions
    Posted by Alistair Gallop on August 20, 2011 at 7:15 pm
    is there a way to specify when you want an expression to start / stop? For example can you animate an object to fly on (motion path) and then for an expression to start?
    Alistair
    Dan Ebberts replied 15 years ago 2 Members · 3 Replies
  • Dan Ebberts
    August 20, 2011 at 7:39 pm
    It depends on exactly what you’re trying to do, but generally it would look something like this:
    timeToStart = 5; // start expression at 5 seconds
    if (time >= timeToStart){
    (your expression goes here)
    }else{
    value
    Dan
  • Alistair Gallop
    August 20, 2011 at 9:49 pm
    so for example if I wanted the pendulum expression to start at 5 seconds it would look like this?
    if (time >= 5){
    veloc = 7;
    amplitude = 80;
    decay = .7;
    amplitude*Math.sin(veloc*time)/Math.exp(decay*time)
    }else{
    value
    Alistair
  • Dan Ebberts
    August 20, 2011 at 10:15 pm
    Yes, except that I left out the closing bracket on the else part:
    if (time >= 5){
    veloc = 7;
    amplitude = 80;
    decay = .7;
    }else{
    value
    Dan
