Starting a New Project in Sony Vegas
Posted by Ric Albano on May 17, 2011 at 1:54 amI want to create an HD video using HD pictures and video to burn to a Blu-Ray. I would also like to save it to my hard drive to once in a while view it on my PC at work etc
I notice when I set my new project in HD settings (blur ray, HDV, AVCHD) that they get slow to work with.
Can anyone reccomend the best workspace for me for the best output?regards,
Ric AlbanoMike Kujbida replied 15 years, 4 months ago 3 Members · 6 Replies -
Danny Hays
May 17, 2011 at 2:45 amWhat are the specs of your computer? Have you tried setting the preview window to Preview/auto to get faster framerate when it plays back? This will degrade the preview quality but add speed to the preview and should not effect your render quality. Hope this helps, Danny Hays
Ric Albano
May 17, 2011 at 2:48 amDan,
I’m using this type of PC
Intel Core Quad CPU @ 2.83 GHZ
8 GB
64 Bit
Windows 7 Home Premium -
Danny Hays
May 17, 2011 at 5:15 amI set my project settings to HD 1080-60i (1920×1080, 29.970 fps) Field order = Progressive, quality = best, deintetlace method = none for slide show HD videos. Just placing them back to back on the timeline, my dual core 3.4 laptop works great with preview set to best / full. Are you using alot of effects? What do you mean gettin slow when project settings are HD, HDV AVCHD. There is no AVCHD project setting. If your talking about rendering that’s different.
Ric Albano
May 21, 2011 at 12:38 pmDan,
Because your computer is like mine. I created 4 projects about 4 to 8 minutes long each because og the regeneration lag. I then decided to put it all together but sections of the cut and paste are left out in the merger. What’s happening
Ric -
Danny Hays
May 21, 2011 at 5:37 pmI’ve never done that so I don’t know. People do something similar called Nesting, where you can add whole projects to the timeline of a new one. Search the help file for Nesting. I’m sure it’s easy.
Mike Kujbida
May 21, 2011 at 5:59 pmNesting is very easy.
Split your project into smaller portions.
Let’s use 4 as an example.
Save each portion as a separate veg file (i.e. myproject-1-1.veg,myproject-1-2.veg, myproject-1-3.veg and myproject-1-4.veg).
Work on each piece until you’re done.
Start a new master project, set your project properties accordingly, import each veg file and drop it on the timeline.
Be advised that they will come in as a single video track and single stereo audio track (5.1 is not supported for nesting), no matter how many tracks were in each one to begin with.
Save it and render out in the desired format(s).
