Activity Forums Apple Final Cut Pro Legacy Started filming on 16:9, switched to 4:3, and now on my computer, it looks 4:3 but horizontally squished
  • Started filming on 16:9, switched to 4:3, and now on my computer, it looks 4:3 but horizontally squished
    Posted by Clarisse Rodriguez on December 31, 2008 at 2:48 am
    Ok, here’s my story:
    I started shooting one day on 16:9. Then a couple of days later, on the same tape, I switched the camera setting to 4:3. Then I uploaded to my computer JUST the 4:3 parts. Now on FCP the image looks 4:3 (no black bars) but slightly horizontally squished (like people’s faces look a little bit longer than they are supposed to be.
    My 2 questions:
    -Does the footage on a tape keeps the setting of when you first started filming ? (16:9 on my case)
    -If all my footage is 16:9 BUT looks 4:3 because there’s no black bars, then is there a setting on FCP that I can use to replace the black bars ? And therefore un-squish the image?
    Thanks!!
    Rafael Amador replied 17 years, 8 months ago 3 Members · 2 Replies
  • Captain Mench
    December 31, 2008 at 11:40 am
    Is your sequence setting 16:9 also?
    Check the clips properties and make sure the ANAMORPHIC tag is OFF. (in the browser… slide to the right quite a ways.)
    CaptM
  • Rafael Amador
    December 31, 2008 at 12:08 pm
    Hi Clarisse,
    Your pictures look wrong in QT because QT Player by default display every kind of pictures as Square Pixels.
    Just make sure that when you import your movies to FC, the 16×9 clips has the “Anamorphic” column checked ON. The 4×3 clips must have that un-checked.
    Happy New Year,
    Rafael
    http://www.nagavideo.com
