Activity Forums Adobe After Effects Start Up Save As Script
  • Start Up Save As Script
    Posted by Sebastian Rasche on September 8, 2018 at 8:27 pm
    Anyone got a script for the after effects startup folder which prompts you to “save as”?
    If you start a new project it is called “untitled” and as far as I know saved nowhere. In order for auto save to work you have to save at least once.
    Sometimes you forget to save and when ae crashes nothings is saved. A little prompt at the beginning of a new project would be cool.
    Sebastian Rasche replied 8 years ago 2 Members · 3 Replies
  • Walter Soyka
    September 11, 2018 at 9:43 am
    Dave is right that saving is a good habit to get into. Discipline is important. But for a more compassionate answer, here’s a simple one-line script that you can use:
    app.project.saveWithDialog();
    Copy and paste that code into a text file, save it as “saveAs.jsx” or similar, and put it in your startup folder. Ae will prompt you on every startup to save the blank file it creates.
    One very important note: this happens at the initial application startup only. If you use File > New > New Project, there will be NO reminder to save.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Sebastian Rasche
    Nobody asked for compassion Dave. I usually save my client projects accurately. But sometimes you doodle around in after effects and forget to save. That’s where a little startup script would come in handy. Thought somebody knew something.
  • Sebastian Rasche
    September 11, 2018 at 9:52 am
    Thank you very much Walter!
