Activity Forums VEGAS Pro Start up problem
  • Start up problem
    Posted by Jessnew on November 19, 2006 at 8:14 pm
    Hi all,
    I’m working on a project which requires me to use quite a bit of music. The other night while trying to open/play all files in a folder(an album) Vegas 7 crashed(I won’t be doing that again, although Windows Media Player seems to handle this task fine). Since that point on start up I receive the following message:
    ! The last session did not complete properly.
    You can restore the autosaved version that was opened, but you should use the
    save as command to rename it. Would you like to restore the autosaved
    project?
    Yes No
    I’ve tried Yes and renamed, I’ve tried No but I still get this message on start up of Vegas. Would anyone have any suggestions on how to get Vegas to not give this message? I also tried returning Vegas to factory defaults and saving another project with no apparent problems, no dice.
    Any help is greatly appreciated.
    Jessnew replied 19 years, 10 months ago 2 Members · 2 Replies
  • Gary Kleiner
    November 20, 2006 at 3:09 am
    It should go away if you shut down Vegas through the File >Exit command.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Jessnew
    November 20, 2006 at 5:40 pm
    Thanks Gary, did the trick. Thought I tried that one but evidently not.
