Activity Forums Adobe Premiere Pro Start premiere sequence from frame 1
  • Start premiere sequence from frame 1
    Posted by Nugas Sayami on February 26, 2015 at 6:38 am
    Premiere always starts timeline from 0. Isn’t it possible to start from frame 1 ?
    It’s possible in After Effects. There should be some way..
    Nugas Sayami replied 11 years, 6 months ago 4 Members · 10 Replies
  • 10 Replies
  • Shane Ross
    February 26, 2015 at 6:45 am
    Timelines should start at 1;00;00;00. Or in Europe, 10;00;00;00. Well, unless it’s for broadcast, then we start at 58;00;00 or so…to allow for color bars and a slate. But program start is always on the 0 frame. You can change that if you want…but I don’t see what that really gets you. If you want to measure the timing of a show perfectly, you need to have the first frame be 00
    Shane
    Little Frog Post
  • Nugas Sayami
    February 26, 2015 at 6:47 am
    But How? I can change timecode but not frames.. How How ?
    I’m actualy working with footages from maya.
    it has counter running from “frame:1”
    Now that needs to sync with premiere’s timeline.
    I can’t seem to find out how to change the frame in premiere. Pls help.
  • Shane Ross
    February 26, 2015 at 11:31 am
    IN the upper left of the timeline, there’s an icon that looks like a box with several horizontal lines. Click on that and a menu will appear. In that menu, choose START TIME:
    Change the number in there to 00;00;00;01
    Shane
    Little Frog Post
  • Nugas Sayami
    February 26, 2015 at 11:32 am
    Thanks but that only changes timecode but not frames. Switch to frames and you will notice the frames starting still from 0.
  • Dennis Radeke
    February 26, 2015 at 12:18 pm
    I would imagine this is so because of the absolute nature of frames and its history in film.
    I’m curious as to why you would want it at 1 as opposed to zero. I’d just like to understand.
    As for fixing it – file a feature request or bug report here: https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
  • Nugas Sayami
    February 26, 2015 at 12:32 pm
    Hi Dennis,
    I’m working with an animation. So, need to keep track of each frames.
    It’s easy for me to start a clip with timecode set to frames and start by 1.
    That way a clip starts with 1 and if it ends at 180frames, then the lenght is simply 180 frames.
    But if that clip had started from frame 0 and ended at 179, that’s same too but I’m always confused with adding or subtracting leading the duration to either 178 or 180 hehehe.
    Anyway, it’s always easy to do math with frames starting with 0 for me atleast. 😀
    For eg, I have 3 clips with following end frames:
    180f
    20f
    200f
    The math is simple for total duration : 180+20+200=400f
    but if it has started with 0f then the math would be complex like below
    179+1+19+1+199+1 = 400f
    Quicktime player is quite miss leading, if you look closely. you will get extra frame at the end and there is no way to set frame to 0 too.
  • Tero Ahlfors
    February 26, 2015 at 1:13 pm
    Preferences – media – frame count – start at 1
  • Nugas Sayami
    February 26, 2015 at 1:15 pm
    Wow, thanks a lot Tero Ahlfors 😀
  • Dennis Radeke
    February 26, 2015 at 2:15 pm
    We are identifying this as a bug and logging it. If you have a company name you want to put next to it, please respond and we’ll enter it next to the bug.
    Dennis – Adobe guy
  • Nugas Sayami
    February 26, 2015 at 3:21 pm
    Thanks Dennis,
    I couldn’t understand how this would happen to be a bug. It’s solved by Tero’s way.
    Still if you want to report it as a bug, here is my info:
    Name: Sagun Manandhar
    Company : Logomator
    website: https://www.logomator.com
    Thanks again,
    Sagun
