Activity › Forums › Adobe After Effects › Start and stop camera shake expression on frames, not seconds
  • Start and stop camera shake expression on frames, not seconds
    Posted by Eric Nicastro on July 13, 2011 at 5:29 pm
    I have the expression for camera shake to start and stop at specific points. But those points are on frames, not seconds. How do I write the expression to start on frame 24 and stop on frame 29 and then again on 1;15 and stop on 1;20? I got the expression sample from Adobe’s website on how to start and stop the wiggle expression at specific points, but it only gave examples of seconds, not frames.
    Walter Soyka replied 15 years, 2 months ago 2 Members · 5 Replies
  • Eric Nicastro
    July 13, 2011 at 5:44 pm
    That worked great! But now I have another problem. The same null object has to wiggle at two different points for two different durations. How do I represent that in the expression?
  • Eric Nicastro
    July 13, 2011 at 5:51 pm
    This is what I have right now:
      timeToStart = .8;
      timeToStop = 1;
      if ((time > timeToStart) && (time < timeToStop)) {wiggle(10,25);}else{value;}
      timeToStart = 1.45;
      timeToStop = 1.7;
    The only expression that’s working is the second one. How do I get both to work?
  • Walter Soyka
    July 13, 2011 at 6:07 pm
    Only the second will seem to work, because they are both always evaluated, and the bottom set is “overwriting” the top set every time.
    You need to add a conditional (if statement) to one or both of the sets so that they will only be evaluated during specific and non-conflicting time ranges.
    There’s also a separate forum for After Effects expressions [link].
    Walter Soyka
  • Eric Nicastro
    July 13, 2011 at 6:12 pm
    I’ll be honest, I really don’t understand what that all means. I get the gist of it, but I’m kind of lost.
  • Walter Soyka
    July 13, 2011 at 10:00 pm
    Expressions are powerful, but there’s a bit of a learning curve. You have to understand quite a bit about how After Effects works, as well as a bit about general programming concepts and Javascript before you can really dive in and work efficiently. Check out Dan Ebberts’s MotionScript web site [link] for a lot more information.
    In the meantime, I suspect it will be a lot easier for you to just use the Wiggler [link] directly on your keyframes:
    • Create a null layer and promote it to 3D. Parent your camera (or your camera’s control, if you’re already using a camera rig) to this null. This way, you can easily change your camera animation and camera shake independently.
    • Add position keyframes to the null at the points in time where you want your shake to begin and end (but don’t actually move the null — just set new keyframes with the default values).
    • Select those two keyframes, then use Window > Wiggler.
    • Start with Apply to: spatial path, Noise type: jagged, Frequency: 10, and Magnitude: 25. (These are essentially the settings in your expression now.)
    Walter Soyka
