Activity Forums Adobe After Effects Start a particle emitter before time zero?
  • Start a particle emitter before time zero?
    Posted by Mark Dyson on November 19, 2012 at 12:54 am
    I have a smoke stream that by time zero, when the animation starts, I want to be fully populated and not just beginning to emit. In Lightwave 3D I’d achieve this by giving the emitter a negative start time so by time zero the stream would be fully populated. I cannot find a similar setting in AE after a lot of searching and digging through textbooks. Can this be done in AE?
    Note: I’m using AE CS6 and CC Particle World.
    Many thanks in advance.
    Vishesh Arora replied 13 years, 10 months ago 3 Members · 3 Replies
  • Ridley Walker
    November 19, 2012 at 1:17 am
    Particle World does not have a pre-run setting. One way to achieve what you want is to move the particle layer to an earlier start time, eg: 3 or 4 seconds before the Comp start time.
    If you have access to Trapcode Particular, it includes a pre-run setting.
  • Mark Dyson
    November 19, 2012 at 1:42 am
    Okay, fair enough. Thanks!
  • Vishesh Arora
    November 19, 2012 at 9:24 am
    Mark
    Simply press ” Alt/Opt + [ ” to cut the particle layer from the point you want your particles to start.
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    Demo Reel(3D):
    https://www.youtube.com/watch?v=lHPgIJU_BR8
