Activity Forums Apple Motion Starstepping while Scaling Graphic
  • Starstepping while Scaling Graphic
    Posted by Dave Martin on December 21, 2006 at 6:50 pm
    Hi Guys
    I have a graphic with alpha channel that I’m scaling from 20 to 60 percent over 3 seconds. The position is also changing slightly (using even numbers). The stairstepping I’m getting is awful. I’ve tried all the deinterlace/flicker filters as well as gaussian blur/broadcast safe etc filters. I’ve tried this in FCP as well as Motion.
    I’m fairly new to FCP but I’m a long time After Effects/Avid/DPS user…Can anyone tell me what I’ve missed?
    I will cross post…Thanks so much!
    Tim Martin
    -MacBook Pro – 2.16GHz Intel Core Duo – 2 gig Ram
    -FCP Studio 5.1.1 – QT 7.1 – OSX 10.4.6 – Lacie D2 dv external drive – G-raid dv drive
    Jim Kanter replied 19 years, 8 months ago 3 Members · 3 Replies
  • Doyle Rockwell
    December 22, 2006 at 4:26 am
    Heya,
    Did you try setting the anti-aliasing mode to ‘Best’? You can find it in the second tab of the Project Properties window (Cmd+J).
  • Dave Martin
    December 22, 2006 at 4:12 pm
    Hi Special
    Definitely have that set…thanks for the reply…
    BTW-we have a spirited discussion over on the FCP forum entitled “Re: Stairstepping on Scaled Graphics (Both FCP and Motion)” if you’re interested….
    Thanks for the reply
    Tim Martin
  • Jim Kanter
    December 25, 2006 at 2:15 am
    Have you tried changing the image size to a smaller one (if you’re only going to 60%)?
    Small-to-large percentages will alias worse than large-to-larger percentages.
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
