Activity Forums Apple Final Cut Pro Legacy Star Wars with a Twist
  • Star Wars with a Twist
    Posted by Sean Lander on May 5, 2006 at 8:00 am
    Ok I’m stumped. Hopefully the collective wisdom of the cow can save me. I need to make text travel up a road. ala Star Wars style.
    My problem is that the road curves away to the right half way up the screen. Effectively what I need to do it distort the text with a bezier.
    But how? I’ve looked at FCP and Motion and can’t seem to find a solution. Any ideas?
    Sean Lander replied 20 years, 3 months ago 4 Members · 5 Replies
  • Joseph Bradley
    May 6, 2006 at 12:14 am
    Well, I checked it out on my FCP 5.0.4 and no luck. The only way I can think of is After Effects.
  • Sean Lander
    May 6, 2006 at 7:24 am
    Yes. So you can do it in After Effects? I haven’t used it for a little while.
  • Zander
    May 7, 2006 at 5:26 pm
    im positive you could this is just making text fallow a path, for referance befor you try, brake up your text into a bunch of smaller chunks.
    this is for 2 reasons, a.e. will work with it better this way
    and secondly think of it as a train, all the cars move seperatly but are pulled by one object, if tey were all one thing the turns would force the train off the tracks, but since they all have a rnage to pivit and move, you can get them to work much better
    also, as a side note, it’s more fear and loathing in lasvagas with a twist, their text fallows a road in the end, it just doesn’t turn
    Aaron Zander
    student editor at brooks institute of photography
    12″powermac g4 1.25gb ram, 1.5 GHZ macosx 10.4.6 1.3tb external space
    finalcut 5.0.4 adobe cs2 afterefects 7pro
    looking for partime work in l.a. area very eager
  • Rob Alexander
    May 7, 2006 at 8:55 pm
    Try here:
    https://peterwiggins.com/motiondownload.htm
    ‘motion wars’
  • Sean Lander
    May 8, 2006 at 12:43 am
    Thanks. Only problem is, is that the text has been rendered into a movie so I need to Bend it Like Beckham!
    I’ve downloaded the trial of AE 7 and it looks like it can do what I need. Pity there seems to be nothing that either FCP or Motion can do.
