Activity › Forums › Apple Final Cut Pro Legacy › Star Wars The Movie – Intro Text
  • Star Wars The Movie – Intro Text
    Posted by Jamesr on August 13, 2007 at 9:35 am
    Hi there, does any one know of a way or better yet – of a plug in to re-create the intro text used at the beginning of the original star wars movie?
    many thanks
    James – UK
    Paul Bosch replied 17 years, 5 months ago 12 Members · 17 Replies
  • 17 Replies
  • Adam1982
    August 13, 2007 at 9:47 am
    If it were me i’d use after effects and move a 3d camera over a text layer, motion i’m sure does this too, alternatively phone industrial light and magic- someone there may still remember the method.
  • Peter Wiggins
    James,
    Two ways of doing it easily,
    1) Motion template here including initial title text
    https://idustrialrevolution.com/component/option,com_sobi2/sobi2Task,sobi2Details/sobi2Id,10/Itemid,/
    2) Free plugin here, you will need to install the FxFactory trial for the plugin to run though.
    https://www.noiseindustries.com/products/fxfactory/free/index.html
    Peter
  • Jamesr
    August 13, 2007 at 10:48 am
    ah thats wicked thanks peter – the plug in is exactly what i was looking for – thanks 🙂
  • Rafael Amador
    August 13, 2007 at 11:20 am
    Peter,
    I tried to use the template few days ago (being in a hurry) and..my God what a mess of text I’ve made:-)
    But I have to get it done because the template is brillant. And why to use a plugin having a bit of time and imagination? Like an in-door game for the rainy season.
    Cheers,
    rafael
  • Walter Biscardi
    August 13, 2007 at 12:01 pm
    This is easily created using the Basic 3D tool in FCP. Just tilt the text back and slide it along front to back.
    For something that looks better, use Motion.
    Better yet, use After Effects.
    It’s all the same idea. Tilt the text on the X axis, scroll it along on the Z axis. You might need to add some motion blur if you’re doing an SD interlaced project.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Tom Wolsky
    August 13, 2007 at 1:40 pm
    Neither the free plugin nor the Basic 3D technique really produce the right look. They simply tilt the text block without the keystoning effect of perspective. A simple way to do it is in iMovie 06. It has a titled effects called Far, Far Away that recreates the Lucas title very well.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Rj Miles
    August 13, 2007 at 11:06 pm
    I’d use AE.
    Build a comp with the text entering/exiting from the bottom/top of the frame.
    Place this comp inside another comp and use the corner-pin plug to adjust the look of the text tilt as desired. Corner-pin adjustment can be used to widen the base as well as narrow the top of the text comp.
  • Chris Poisson
    August 14, 2007 at 11:57 am
    There’s a subtle, yet important aspect of this effect that I don’t see listed here, it’s the way the text blurs and then fades at the top, pretty easy to miss or NOT do correctly.
    That aside, there is a little free app called SWTSG which is absolutely amazing, you simply enter your text and it’s done. Here’s the link:
    https://alienryderflex.com/crawl/
  • Gabriele De simone
    August 14, 2007 at 12:59 pm
    Our freebie plug-in (mentioned earlier) *does* give you control over the text blurring as it fades into the distance. Because of the way the blur is applied (non-uniformly, via a depth mask) it also makes the colors fade away as they scroll to the back.
    Star Titler comes with an image well to specify your own background and rotate it via a sphere map, which in my humble opinion is pretty neat 🙂
    https://www.noiseindustries.com/fxfactory/free
    If you have suggestions for improving the plug-in, I can’t imagine a more appropriate thread than this one to collect them…
    Gabe
    noise industries
  • Curious Editor
    December 3, 2007 at 5:39 pm
    Wow Thanks Chris!
    So far that’s the best thing I have ever seen! Now to figure out how to tilt down and add more stars. I was afraid that it couldn’t be rendered in 1080 but it does, simply WOW! And it free!! No BS trial version.
