Activity › Forums › Adobe After Effects › Star Wars Text Scroll
Posted by Chip Hess on March 16, 2012 at 11:41 pmClient is looking for that old fashioned serial look we saw in Star Wars. Text starts huge and close at screen bottom and diminishes in size at it moves into the distance and offscreen, skewed.
How does one create this in AE, thanks!
Isaac Borjas replied 14 years, 5 months ago 6 Members · 6 Replies -
Conrad Olson
March 17, 2012 at 12:12 amThe easiest way would probably be to create regular scrolling text and then use the corner pin effect to add the perspective.
Angelo Lorenzo
March 17, 2012 at 3:14 amI’d disagree. I’d say normal text, turn on 3D switch and move active camera. Should give distance perspective including the possibility to light the text as well.
Tudor “ted” jelescu
March 17, 2012 at 2:26 pmAll the above will work, my method: text layer turned 3d and positioned in front of camera (not moving the camera but the layer). Adjust the lens angle (wide) for perspective.
Tudor “Ted” Jelescu
Senior VFX Artist -
Isaac Borjas
March 17, 2012 at 2:29 pmthe way iknow how to do it is the follow…
– create de Txt.
– make it 3D
– now adjust the X Rotation to requiere position (-70 is good)
– now animated the ANCHOR POINT in the Y axishope that help
Isaac Borjas
March 18, 2012 at 3:12 pmin my spare time today i create this sample, inside the Description Box is the Project file….No Camera need it
https://www.youtube.com/watch?v=EnIFjG5ZeN0
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
