Activity › Forums › Adobe After Effects › Star wars effect
Star wars effect
Posted by 50calguy on September 6, 2007 at 4:34 pmHello
Im making a starwars spoof and need help with an effect. You know when a ship goes into hyperspace and the stars get stretched out into lines, anyone know how I can create that?
thanks
jasonJulio Fernandez replied 17 years, 7 months ago 6 Members · 6 Replies -
Steve Roberts
September 6, 2007 at 4:37 pmRadial Blur, set to zoom?
(it’s a render hog, though … be prepared to wait) -
Kevin Camp
September 6, 2007 at 5:12 pmi think you could also do this with particular, using the aux system to emit from the main particles (the main particles being the stars).
if you have particular, i could walk you thru a set up to get started with…
you could also use cc particle world to create a starfield fly thru… not quite the same effect, but might work for you if you don’t have another 3d particle system, or zoom blur doesn’t work.
Malcolm Desoto
September 6, 2007 at 9:44 pmAndrew Kramer also has a tutorial on the Mac/ipod light streaks. You could probably achieve what you’re after with a few tweaks to that method.
Rutger
September 7, 2007 at 12:32 amI think there is a fairly easy method as follows:
– Create a starry sky using the same method Andrew Kramer used in his Earth tutorial. This means adding a solid and using Fractal noise. I used the following settings:
Fractal Type Dynamic, Noise Type Soft Linear, contrast = 600
, brightness = -280. Now, you should see stars on a black background.
– Turn this layer to be 3D
– Animate it such that it moves towards the camera in z-direction only.
– Precomp this (Ctrl-shift-C), move all attributes
– Then apply the Echo Effect to the precomp
– keyframe the number of echos, starting at 0 to about 250
– Add glow and use toner as you like.All it needs is a little sound effect and you should be done.
Hope this helps
Rutger
Julio Fernandez
January 27, 2009 at 9:59 amHi moldyboot,
I would appreciate very much if you can do the walktrough using particular….
Thanks in advance
