Activity Forums Apple Final Cut Pro Legacy Star Trek “transporter” effect in FCP5?
  • Star Trek “transporter” effect in FCP5?
    Posted by Danyux on July 13, 2005 at 3:36 pm
    I’ve seen this described before, but can’t seem find
    it again. Does anyone know how to create the
    lights-sparkling-vanishing effect used in Star Trek’s
    “transporter”? I know it can be done in After Effects,
    but what about FCP5? I’m starting with a locked
    down shot of the subject, along with the same background
    shot without the subject. The question is, how do you
    create the transition.
    thanks,
    Dan
    Gary Hughes replied 21 years, 2 months ago 2 Members · 1 Reply
  • Gary Hughes
    July 15, 2005 at 2:22 pm
    I would use motion (or particle illusion or after effects) to create a particle system with the look that you want for the sparkly stuff, then render that out using the animation codec with alpha, then put it on a track in fcp over the video. You could use a dissolve on the video, or a gradient wipe from top to bottom. Make it soft for a more dreamy effect and make the particles move at about the same speed as the wipe.
    If you have motion, you could edit the video first, then round-trip them into motion to create the particle system for a perfect match.
    Good luck,
    Gary
