Activity › Forums › Square Box CatDV › Star Ratings?
Star Ratings?
Posted by Chris Sgaraglino on July 12, 2011 at 2:44 amUsing star ratings instead of the old good/no good/maybe classification is cool, however, when I upgraded, it did change the classifications.
What Start # did you change the classification to?
Warm Regards,
Chris Sgaraglino
Outdoor Studios Photography || on Flickr || on TwitterChris Sgaraglino replied 15 years, 1 month ago 2 Members · 7 Replies -
Rolf Howarth
July 12, 2011 at 8:31 amIf you use star ratings in CatDV 9 they’d be lost if you exchange catalogs with someone using CatDV 8 so if you edit the ratings it will change the ‘good’ status, and vice versa, using the following equivalences:
Unrated = 0 stars
No good = 1 star
Maybe? = 2 stars
Good = 4 starsThis means that if you switch between versions you won’t get the nuances of 3 or 5 star ratings but at least you won’t lose your ratings altogether.
Chris Sgaraglino
July 12, 2011 at 11:53 am -
Chris Sgaraglino
July 13, 2011 at 2:10 amHow do I change the bottom grin column Good, to show number of stars instead of Good, Maybe?, etc?
Warm Regards,
Chris Sgaraglino
Outdoor Studios Photography || on Flickr || on Twitter -
Chris Sgaraglino
July 13, 2011 at 3:01 pmI already have GOOD in the list – the issue is that the data for this column is “blank, no good, good, maybe?” NOT 1,2,3,4, or 5 stars?
Warm Regards,
Chris Sgaraglino
Rolf Howarth
July 13, 2011 at 3:28 pmYou need to customise the view, remove Good and add Rating instead.
Chris Sgaraglino
July 13, 2011 at 9:15 pmGreat – that worked, thanks!
Warm Regards,
Chris Sgaraglino
