Activity › Forums › Panasonic Cameras › Standard Monitoring
  • Standard Monitoring
    Posted by Saw Media on May 26, 2007 at 2:59 pm
    Hello. I’m testing a AJ-HDC27HP for the first time and I’m limited to a monitor that only offers a composite input. Should I still be able to get some type of image? I haven’t had any luck so far. Thank you in advance for your help.
    Scott-
    Saw Media replied 19 years, 4 months ago 3 Members · 3 Replies
  • Chris Bell
    May 26, 2007 at 4:27 pm
    You need an HD monitor with an HD-SDI input.
  • John Sharaf
    May 26, 2007 at 4:48 pm
    Scott,
    Sorry, but the Varicam is an HD camera with no internal downconvert either standard or as an option. There are third party converters from sources like AJA, but mostly for use on Steadycams and Jibs that are already outfitted with specialized SD monitoring. For general HD moniroring the standard entry level monitor seems to be the Panasonic 8.4″ HD LCD. It can be used mounted on the camera, more or less as a color viewfinder, or seperated from the camera with a battery attached (it has an AB plate on the back) for the director to look at.
    It is not totally adviseable to use a SD monitor for HD production as the color gamut is different and issues of focus cannot be properly addressed. Simply put, an HD monitor should be part of ant basis HD camera package and I just include it in my package rate when I rent out Varicams.
    JS
  • Saw Media
    May 26, 2007 at 5:07 pm
    Thought that might be the case, but not being totally familiar with the camera…just wanted to double-check. Just picked up Goodman’s Guide, so I’ve been digging around in there, great book. Thank you.
