Activity Forums DaVinci Resolve Standard Candle
  • Standard Candle
    Posted by Sascha Haber on June 23, 2011 at 11:10 am
    Hi guys ,
    I like benchmarking , and of course we all want to know if our triple 4800 Setup still can beat the Hackintosh guys out there, right ?
    So, I sat down and tried to develop a non-disk-all-GPU benchmark for us to use.
    Or as the astronomer would say :
    “A standard candle is a class of astrophysical objects, such as supernovae or variable stars, which have known luminosity due to some characteristic quality possessed by the entire class of objects. Thus, if an extremely distant object can be identified as a standard candle then the absolute magnitude M (luminosity) of that object is known.”
    This is the link to the Resolve project :
    https://www.yousendit.com/download/MFo1ckhlZDU5RlpFQlE9PQ
    The images used are the “Sample Images” from the Installer .
    Copy the folder somewhere , import the project and relink the files.
    The project consists of the three clips with some settings applied.
    Its a standard project with standard HD 24PsF settings and the images will be scaled up to fill.
    I created nodes with some color, blur mask and either blur or sharpening.
    The memories A-H are filled with repetitions on the same nodes.
    The higher the letter, the more nodes.
    On my GT120/GTX285 system I can use setting A and B with 24fps, from memory C on it drops frames .
    That is 5 nodes…Memory H has 20 or so, but it seems you can add more nodes without drastically reducing performance.
    This is just a first draft and I am open for suggestion to make it more elaborate.
    But please give it a shot and lets share results..
    Have fun testing.
    A slice of color…
    DaVinci 7.1.2 OSX 10.6.7
    MacPro 5.1 2x 2,4 24GB
    RAID0 8TB eSata 6TB
    GTX 285 / GT 120
    Extreme 3D+ WAVE
    http://www.saschahaber.com
    Colin Travers replied 14 years, 7 months ago 12 Members · 20 Replies
  • 20 Replies
  • Andi Winter
    June 23, 2011 at 12:18 pm
    love your idea…
    but i am unable to import the xml-file. i cant do this in resolve 7 i guess and my fcp drops some
    error message… so i cant participate…
    plz post a standard resolve project, or gimme further instructions, perhaps i overlooked something.
    andy
  • Sascha Haber
    June 23, 2011 at 2:14 pm
    Go the project tab, right click the project window, say ” import+” and select the .tar.gz file.
    Resolve will import the project for you, you just need to reconnect the media then .
    A slice of color…
    RAID0 8TB eSata 6TB
    GTX 285 / GT 120
    Extreme 3D+ WAVE
  • Rohit Gupta
    June 23, 2011 at 2:18 pm
    Make sure Safari doesn’t uncompress/rename the file for you when it finishes downloading.
    i think resolve expects it to be in the compressed format before if will let you import the project.
  • Vladimir Kucherov
    June 23, 2011 at 4:33 pm
    I just opened this up and the memories are empty. Not sure why – is it possible A-Z don’t get exported? Maybe it’s better to make some stills?
    The grades are there though so I can just duplicate the nodes for the same effect.
  • Vladimir Kucherov
    June 23, 2011 at 4:51 pm
    Resolve 7.1
    4 nodes – 24fps
    5 nodes – 20fps
    6 nodes – 17fps
    Resolve 8 (latest beta)
    4 nodes – 24fps
    5 nodes – 20fps
    6 nodes – 17.5fps
    with Bilinear resize on: +1.5fps
    SYSTEM:
    2.66GHz Mac Pro 12 core
    6gb RAM
    GUI: GeForce GT120
    CUDA Proc: 1x GeForce GTX285
    Video: Blackmagic Decklink Extreme 3D
    Media Pool Drive: 4 drive software mac raid
    CUDA Driver: 4.0.17
    Decklink Driver: 7.9.5 (Resolve version)
  • Andi Winter
    June 23, 2011 at 8:29 pm
    hi again!
    thanks, now it works. but as vladimir mentioned, the memories are empty… 🙁
    and, i cant duplicate nodes, can i?
    playing back the test (first 2 nodes, second 4 nodes, third 6 nodes) i have 24 frames.
    maybe you could upload another version of the test with more nodes as scene 4, 5 and so on?
    my spec: double gtx480 🙂
    andy
  • Vladimir Kucherov
    June 23, 2011 at 8:32 pm
    Andy, try grabbing a still, and then open the still’s node graph. You can from there drag nodes into your grade over and over.
  • Andi Winter
    June 23, 2011 at 8:59 pm
    thx.
    you are right, i can.
    now the parrot i can playback with 9 nodes max until i get a lower fps than 24:
    9 nodes – 24fps
    10 nodes – 22
    11 nodes – 20 to 20.5
    12 nodes – 18.5 to 19
    20 nodes – 13 fps
    andy
  • Andi Winter
    June 23, 2011 at 9:02 pm
    and ps: i do only have two gtx480 right now, so one does the gui (and perhaps helping with cuda?) and the other one is purely for cuda. if i have some time i will get a cheap third card for gui.
  • Sascha Haber
    June 24, 2011 at 1:35 pm
    Cool, that sounds like the double performance I have with my “standard” setup.
    It would be great if more people could do tests and share results, especially Cubix DUal card setups and one card solutions are interesting then.
    A slice of color…
    RAID0 8TB eSata 6TB
    GTX 285 / GT 120
    Extreme 3D+ WAVE
