Activity › Forums › DaVinci Resolve › Standard Candle v82
Standard Candle v82
Posted by Margus Voll on March 20, 2012 at 12:02 pmHi.
I just did re upload Standard Candle test that Sascha made.
I just exported from V8.2
Feel free to download:
https://www.iconstudios.eu/Standard Candle v82.resolve.tar.gz
Please report your results if you have new exiting setups with gpus.
Margus
Blase Theodore replied 14 years, 4 months ago 9 Members · 19 Replies -
Knut Jansohn
March 20, 2012 at 7:30 pmHi Margus,
nice, but due to the blanks it seems that the link doesn’t work?
Regards
K
Margus Voll
March 20, 2012 at 8:09 pmI will put up both version then.
For me on Chrome on mac it worked perfectly if you copy pasted the whole url.
Here is with no spaces.
https://www.iconstudios.eu/Standard_Candle_v82.resolve.tar.gz
Look if this seems better?
Margus
Benoit Cote
March 21, 2012 at 6:24 pmThanks Margus for re-posting that file !
Here are my results (Cubix desktop4 with 3 quadro 4000 gpus) :
V1 2 nodes : 24 fps
V2 4 nodes : 24 fps
V3 6 nodes : 24 fps
V4 12 nodes : 19 fps
V5 NR 4 : 24 fps
V6 NR 4 : 14 fps
V7 NR 4 : 16 fps
V8 NR 4 : 4 fpsdisappointment
Benoit Cote
Colorist
http://www.lacavalerie.caDaVinci 8.0.1 OSX 10.6.8
MacPro 5.1 2×2,6 12GB
RAID5 36TB MetaSAN
Quadro 4000 x4 Cubix Desktop 4
Extreme 3D+ Wave -
Margus Voll
March 21, 2012 at 6:37 pmHi.
I have 4000 as gui gpu and 470 as resolve gpu and i get something like this:
V1 2 nodes : 24 fps
V2 4 nodes : 24 fps
V3 6 nodes : 22 fps
V4 12 nodes : 12 fps
V5 NR 4 : 24 fps
V6 NR 4 : 19 fps
V7 NR 4 : 9 fps
V8 NR 4 : 2 fpsI tested on 10.7.3 and with 6 gig ram. Mac Pro 5,1 dual 6 core @ 2.93 ghz.
Sasha got a bit better results but i think it is something to do with my ram being only 6 gigs.
Generally my system is the same he does but he got a bit better results.You probably should change those 4000 as they are not as fast as one would think.
You probably have seen here daily about 5xx series and probably 6xx series gpu’s.—
Margus
Sascha Haber
March 21, 2012 at 6:58 pmI am having the same numbers with ONE 470 in the machine.
Sorry to tell…A slice of color…
DaVinci 8.2.1 OSX 10.7.2
MacPro 5.1 2×2,4 24GB
RAID0 8TB
GTX 470 / Quadro 4000
Extreme 3D+ICA Instructor
https://www.icolorist.com/Sascha.html -
Benoit Cote
March 21, 2012 at 7:23 pmDon’t be sorry Sascha, those numbers are just THE good reason to get the 3x gtx680 next friday !!
From what I can see from previous post, there is not much difference between a double and a triple quadro 4000 setup… I knew our setup wasn’t that powerful but I thought the third 4000 was making a bigger difference.
No particular problem running those flashed 470 card?
Also, with the recent break in nvidia support (10.7.4 beta update), would you buy a pc gtx580 or 680 anyway or you would stick with flashed cards?Benoit Cote
Colorist
http://www.lacavalerie.caDaVinci 8.2 OSX 10.6.8
RAID5 36TB MetaSAN
Extreme 3D+ Wave -
Aaron Hayden
March 22, 2012 at 2:02 amId like to run this on my windows box with 3 gtx 580’s and a quadro 4000, but i can’t get it to import into resolve.
Gives me the error “failed to open archive!”
Is it not possible to open mac resolve projects on a windows resolve box?
Aaron Hayden
Colorist
Gurney Productions -
Margus Voll
March 22, 2012 at 8:53 amI just made zip version also:
https://www.iconstudios.eu/Standard_Candle_v82.resolve.zip
See if it helps?
Margus
Aaron Hayden
March 22, 2012 at 10:37 pmNow it works, Thanks!
Here are my results.
V1 2 nodes : 24 fps
V2 4 nodes : 24 fps
V3 6 nodes : 24 fps
V4 12 nodes : 24 fps
V5 NR 4 : 24 fps
V6 NR 4 : 24 fps
V7 NR 4 : 24 fps
V8 NR 4 : 12 fpsSystem info:
SuperMicro 7046gt-trf
2 x xeon X5690 3.47 GHZ
24 gigs of ram
1 quadro 4000 for gui
3 gtx 580 for gpuAaron Hayden
Colorist
Gurney Productions
