Activity Forums Adobe After Effects Stamp Tool Crashes
  • Stamp Tool Crashes
    Posted by Angel Nieves on November 5, 2013 at 10:52 pm
    Using AE CS6. My stamp tool is crashing after painting a few frames. I was able to use it successfully before but then it started freezing, and haven’t been able to use the stamp tool since. Any ideas anyone? Can’t find anything online.
    Angel Nieves replied 12 years, 10 months ago 2 Members · 4 Replies
  • Mathew Fuller
    November 5, 2013 at 11:20 pm
    Depending on your AE version… try switching from Open GL to Adaptive resolution. It’s the little lightning bolt at the bottom of your comp view.
    My Work:
    https://www.morecompletefx.com
  • Angel Nieves
    November 6, 2013 at 12:24 am
    It was already on Adaptive Resolution, but thanks for replying.
  • Mathew Fuller
    November 6, 2013 at 12:33 am
    Then try open gl.
    My Work:
  • Angel Nieves
    November 6, 2013 at 12:57 am
    Don’t have that in CS6. I don’t think it has anything to do with that. As I’ve done more research I realized that CS6 is 64 bit. Before I was working in 32 bit. I don’t have enough RAM on my laptop. That’s probably what’s freezing it up. I may have to reinstall CS4 in order to use the stamp tool. Again, thanks for trying.
