Activity Forums Apple Final Cut Pro Legacy stammered playback on AE render
  • stammered playback on AE render
    Posted by Danny Ellen on September 27, 2010 at 2:36 pm
    Hello,
    I’m editing a project in Apple ProRes, 1280 x 720, 23.98 fps.
    I’m bringing in a rendered title from After Effects.
    Problem: The title is playing back ‘stammered’ –it is getting stuck on certain frames for 2 or 3 frames, and then jumping forward.
    Interestingly, I’ve found that in ‘Video Processing’ under Sequence Settings, if i select always render in RGB, and play the title as a real-time effect (ie, with a light-grey bar, ie, ‘Full’) the title plays smoothly. However, when i render the sequence for output (which I think I have to!)–and the title’s bar becomes blue–the playback becomes stammered again!
    Any help would be much appreciated!!
    Danny
    Danny Ellen replied 15 years, 11 months ago 2 Members · 5 Replies
  • Danny Ellen
    September 27, 2010 at 2:37 pm
    p.s., all my AE render setings match my fcp sequence settings.
  • Danny Ellen
    September 27, 2010 at 2:46 pm
    Just to clarify, the title is playing back smoothly in AE, and the rendered file is playing back smoothly in Quicktime. It’s only when I bring it into FCP and render it does it become ‘stammered’. And again,all my AE render settings match my FCP sequence settings. (Apple ProRes 422, 23.98 fps, 1280 x 720).
    Thanks.
  • Danny Ellen
    September 27, 2010 at 2:54 pm
    Well, I think I’ve solved my problem!
    I was rendering in ProRes (HQ)…. but my fcp sequence is ‘non-HQ’—just regular Apple ProRes.
    It doesn’t seem like mixing those 2 formats should cause this problem!!! But still, I’m happy that I have a non-stammering title now!! So thank you.
    Best,
    Danny
  • John Fishback
    September 27, 2010 at 5:22 pm
    Something else to consider… Make certain that AE’s frame rate is set to 23.976 – not 23.98. 23.98 is simply shorthand FCP uses for 23.976. The thing is – AE takes your input literally. Playing true 23.98 in a 23.98 FCP sequence (which actually wants to see 23.976) often stutters.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
  • Danny Ellen
    September 27, 2010 at 6:06 pm
    thank you John, I’ll try that!
