Activity › Forums › Maxon Cinema 4D › Stair Walk Animation
  • Adam Trachtenberg
    April 14, 2014 at 9:15 pm
    Just select iPMocap:Hips track in the timeline and in the Attributes Manager set Track Properties>After to Offset Repeat. Then set the number of repetitions you want.
  • Lothar Wieland
    April 14, 2014 at 9:21 pm
    You are genius! Thanks a lot thousand times. It works exactly what i had in mind!!!! Thanks again. 🙂
