Activity Forums Apple Final Cut Pro Legacy Staggering Outline Text
  • Staggering Outline Text
    Posted by Danny Greer on August 30, 2006 at 5:13 pm
    When I keyframe outline text to go from one size font to a larger one (say, in the span of 10 seconds) it staggers horribly. I have checked the RT to safe and the video quality to Low (in FCP playback) and no luck. In fact, when I export the sequence to a QT file, I still get the text size staggering during a size increase. Does anyone have any suggestions? Also, it is worth noting that this does not happen if I use regular text, only outline text.
    Thanks.
    dg
  • Bouncing Account needs new email address
    August 30, 2006 at 6:16 pm
    A assume you mean you are scaling up the size of the image (zooming in), and not increasing the actual FONT size IN the title.
    Are you starting with a large-size font in the original; title and then scaling it back before you start?
    You should not attempt to start with, say, a 25 point and try to “zoom in” to make it a 50 point.
    (You’d want to type it in a 50 and use the “scale” setting to make it a 25, first.)
    Regardless, scaling or rolling or panning text/graphics on-screen will always cause a certain amount of “line-crawl” as it moves.
    You can try adding a Gaussian Blur filter to the graphic set to a 0.25 to 3.0 setting and be sure to RENDER.
    Make sure that your start and end-points on the “move” are on FULL, EVEN numbers in the vertical position setting.
    And be sure to only monitor for QUALITY only on an external NTSC (or PAL) monitor.
