Activity Forums Adobe After Effects Expressions Stagger opacity
  • Posted by Judy Ranelli on April 24, 2015 at 5:38 pm
    I’m new to expressions and playing with staggering the opacity from 0-100 on 80 layers, with keyframes on the 1st layer. Not working. Any suggestions?
    m=thisComp.layer(1).marker.key(1)time - thisComp.layer(1), inPoint;
    thisComp.layer(thisLayer,-1).transform.opacity.valueAtTime(time-M);
    Layer 1 has two keyframes, 0 opacity at frame 1 and 100 opacity at frame 30.
    Ilya Sire replied 11 years, 1 month ago 3 Members · 6 Replies
  • Dan Ebberts
    April 24, 2015 at 6:59 pm
    Your expression has a few issues. What are you trying to do exactly (e.g. what do you mean by “stagger opacity”)?
    Dan
  • Judy Ranelli
    April 24, 2015 at 7:02 pm
    I want layer 1 to go from 0 to 100 opacity over time of 1 second. and once layer one is at 100% opacity then layer 2 would go from 0 to 100 opacity and so forth through the rest of the layers.
  • Dan Ebberts
    April 24, 2015 at 7:14 pm
    There are a number of ways to approach it, but one way would be to give each layer this opacity expression:
    dur = 1; // 1 second
    tStart = (index – 1)*dur;
    tEnd = tStart + dur;
    linear(time,tStart,tEnd,0,100)
    Dan
  • Judy Ranelli
    April 24, 2015 at 7:26 pm
    Is there a way to make the expression so that if I adjust the keyframe timing on layer 1, it adjusts for the other layers? For instance if I made the opacity on layer 1 go from 0 to 100 over 45 frames instead of 30… then the timing on the other layers adjusts as well?
  • Dan Ebberts
    April 24, 2015 at 7:37 pm
    Something more like this, probably:
    p = thisComp.layer(1).transform.opacity;
    if (p.numKeys > 1){
    dur = p.key(p.numKeys).time;
    tStart = (index - 1)*dur;
    t = time - tStart;
    p.valueAtTime(t);
    }else
    value
    Dan
  • Ilya Sire
    July 14, 2015 at 9:01 am
    Hi Dan, i found this code and how can i make this from 0% and 100% after second variable? Not like fade in just On Off opacity.
    Thank you
    Sire
