Activity › Forums › Apple Final Cut Pro Legacy › Stagetools Moving Pictures
Posted by Jimmy Spangler on June 14, 2008 at 2:49 amDo any of you out there use StageTools Moving Pictures?
It takes an eternity to render 1080 picture moves with this thing. And it also has a ton of quirks.
Does anyone use it successfully? Anyone have any alternatives to do better moves than FCP basic motion can handle?
Jimmy Spangler replied 18 years, 3 months ago 5 Members · 7 Replies -
Shane Ross
June 14, 2008 at 3:20 amMotion does a great job.
Shane
Read my blog, Little Frog in High Def -
Jimmy Spangler
June 14, 2008 at 4:57 amHow well does Motion work when you have say 75 images that need motion in a 30 minute 1080p ProRes project? Is it manageable and easy enough to go back into motion to tweak a move?
Thanks for the help.
Chris Poisson
June 14, 2008 at 12:42 pmJimmy,
Go ahead and check out Motion, but take a look at Fotomagico too. I compared it with Moving Picture a few years back, FM won hands down.
Have a wonderful day.
Dan Brockett
June 14, 2008 at 11:43 pmI bought the Core Melt ImageFlow for stills using Motion and I love it. Motion rocks. Doing movement on stills in FCP is a PITA but in Motion, it is easy and quick.
Dan
Providing value added material to all of your favorite DVDs
Lars Fuchs
June 15, 2008 at 1:23 amI use the Lyric Pan Zoom Pro plug-in. I generally like it. It isn’t perfect, but I find it much easier to use than StageTools. I have been thinking about using Motion for a while. I suspect that I may use Lyric as a ‘quick-and-dirty’ tool to handle 90% of the work and do critical stuff in Motion.
Chris Poisson
June 15, 2008 at 3:30 pmI use the Lyric plug too, but it takes a bit of time to render. Fotomagico is very fast.
Jimmy Spangler
June 15, 2008 at 7:16 pmIs Fotomagico a plugin or a standalone program? Ideally I would like to stay in the timeline so if there are changes, they could easily be made.
