  • Posted by Lee Brennan on September 2, 2008 at 11:09 pm
    When I set the stage size in PI3 to 720×480 and pull in a clip I captured in Vegas Pro 8(720 x 480) a window comes up and says the “Image is not the same size as the stage-make stage same size as image?” If I right click the clip (in Vegas) and go to “properties” it tells me that the clip is: Width 720 pixels ; Height 480 pixels.But when I pull that clip into PI 3 it tells me the “image is not the same size…”.If I set the stage the same size as image it sets it at 360×240. If I don’t set the stage to the same size as image it also sets the clip as 360×240. What am I doing wrong? Thanks.
    Alan Lorence replied 17 years, 12 months ago 2 Members · 3 Replies
  • Alan Lorence
    September 4, 2008 at 5:53 pm
    When you look at the movie in Windows (not Vegas), what size does it think it is?
    Alan.
    http://www.wondertouch.com
  • Lee Brennan
    September 4, 2008 at 10:33 pm
    When I pull the clip into Windows Media Player and click on File- Properties it tells me that the video size is: 720 x 480 and that the aspect ratio is: 4:3 actual, 16:9 displayed. Thanks for any insight you might have on this.
  • Alan Lorence
    September 8, 2008 at 5:26 pm
    No ideas. If you’re still having a problem, please send a SHORT (10-frame) clip that exhibits the problem to support at wondertouch dot com and we’ll take a look at it. Please ZIP the clip too, and verify that it has the problem for you before sending it.
    Alan.
