Activity › Forums › VEGAS Pro › Stage Lighting washout overexposure on only one person
  • Stage Lighting washout overexposure on only one person
    Posted by Bob Ivory on October 8, 2016 at 7:46 pm
    The stage lighting on a last minute job was too bright on one area of the stage.
    Unfortunately is was the on the main artist.
    I will fix the lighting problem at the source for future event at this location.
    I know overexposure is a point of no return problem.
    But… I could use help trying to soften/correct this current video
    Some of the new plug ins are unfamiliar to me.
    I’ve used vegas pro 9 on and off for several years.
    I’ve upgraded to vegas pro 14.
    I’ve read many post on color correction and levels.
    but my research time is running short.
    Thank you. I respect and appreciate all I have already learned just by reading existing posts
    here is screen shot.
    Bob
    Bob Ivory replied 9 years, 11 months ago 2 Members · 2 Replies
  • Mike Kujbida
    October 9, 2016 at 2:31 am
    Bob, here’s a technique I stumbled across on the Sony Vegas forum a few years ago.
    Put 3 filters, a “Invert” (at 100%), “Color Corrector”, “Invert” (at 100%).
    Then lift up the gamma of the color corrector in the middle.
    This darkens highlights first, in the logarithmic fashion, more like a “iris closing” way.
    You can also put a color corrector secondary to select reds and lower the gamma a bit.
    Here are two screen shots for you.
    The first one is the setting I used.
    The second is after my (rather limited) attempt at correction.
    I masked the singer on the right so that any adjustments would only affect her.
    Feel free to play around as needed. Good luck.
  • Bob Ivory
    October 10, 2016 at 1:57 pm
    Thanks Mike,
    I’m working to see what improvements I can get with this trick.
    Then I need to brush up on masking to leave the rest of the video alone.
    …” and another learning journey begins.”
    Bob
