Activity Forums Adobe Premiere Pro Stacking multiple audio clips when dropping them in a sequence
  • Stacking multiple audio clips when dropping them in a sequence
    Posted by Matt Hogan on March 18, 2015 at 3:57 am
    Currently when you select multiple audio tracks and drag them into the timeline, premiere places them one after another on a single track. Is there a way to have each audio clip land on a separate track? I have up to 4 tracks of audio to synch up and it would be much faster if they would all land on separate tracks. Any suggestions?
    Brian Scott replied 9 years, 4 months ago 3 Members · 3 Replies
  • Kinga Rup
    September 7, 2016 at 2:13 pm
    Hi Matt, I’m searching for the same solution, have you found out any shortcut? thanks
  • Brian Scott
    January 24, 2017 at 8:05 pm
    I found a way that is a little faster. If you select the 4 tracks in the project pane and right-click you can select “Merge clips”- when you do that Premiere creates a new 4 channel clip. I created an “audio” folder with a folder called “orig” nested in it. After I merged the first 4 clips I moved them to the “orig” folder. I kept doing that until I had merged them all. That way I didn’t get confused as to which ones I had already worked on.
    Hope that helps.
    Brian Scott
    President
    Image Design Productions, Inc.
  • Brian Scott
    January 24, 2017 at 8:19 pm
    There is a caveat – once you merge the audio clips you can’t merge them with a video clip – the option is grayed out.
    Brian Scott
    President
