Activity › Forums › Adobe After Effects › staccato cog animation
  • staccato cog animation
    Posted by Joanna Goldman on May 19, 2015 at 8:22 pm
    I’m trying to animate a cog piece in a watch. I want it to rotate 360, but have it pause after each small movement. Animation like this one: https://www.youtube.com/watch?v=hD9rF0Mt2sE
    Is there an expression that I can use on the rotation to make it pause like this?
    Walter Soyka replied 11 years, 4 months ago 2 Members · 1 Reply
  • Walter Soyka
    May 20, 2015 at 1:33 am
    Rotation is measured in degrees, and there are 360 degrees in a full rotation. A full rotation is 60 seconds. Therefore, every second, we want to move 6 degrees (360/60).
    This expression:
    time*6
    will gives us a smoothly-sweeping second hand.
    To make it click once per second, we can use posterizeTime(), which forces Ae to update the property value at a different frame rate than the comp. Using a value of 1 tells it to update at one frame per second, for your perfect staccato second hand:
    posterizeTime(1);
    time*6;
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
