Activity › Forums › Adobe After Effects › Stabilizing scans
  • Stabilizing scans
    Posted by Thomas Vermaercke on May 19, 2015 at 5:56 pm
    Hi everybody!
    I’m having trouble stabilizing a handdrawn animation.
    Every frame looks like this:
    Stabilizing should be done using the two black squares.
    I tried using the point tracker in After Effects, but the individual scans differ too greatly in position. This confuses the tracker.
    Any thoughts on how to fixate these two squares for every frame?
    Greetings
    Thomas
    Ross Shain replied 11 years, 4 months ago 4 Members · 5 Replies
  • Michael Szalapski
    May 19, 2015 at 8:26 pm
    You can make the search area larger on the point tracker. Or you could track in Mocha.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Thomas Vermaercke
    May 19, 2015 at 8:52 pm
    I already tried making the area larger.
    Is Mocha much better?
  • Michael Szalapski
    May 19, 2015 at 9:54 pm
    Not “better” just different. It uses completely different technology for tracking which makes it better for some things and worse for others.
    – The Great Szalam
  • Walter Soyka
    May 20, 2015 at 1:25 am
    [Thomas Vermaercke] “Stabilizing should be done using the two black squares.”
    If those black squares are hand-drawn, too, the variation from frame to frame could be enough to mess up your track. You might be better off with a printed hashmark or maybe just an ink dot.
    Have you tried the warp stabilizer on the clip?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Ross Shain
    May 21, 2015 at 1:53 pm
    That is a good point. Your best bet would be to print a sticker image with a pattern for each frame, rather than draw it yourself. This is a typical motion tracking marker image:
    https://ridgelinetutorials.com/blog/free-motion-tracking-markers
    Note that planar tracking is probably overkill for this. Simple point tracker should work fine.
    Ross Shain
    Imagineer Systems
    http://www.imagineersystems.com
