Activity Forums Adobe After Effects Stabilizing Motion with a shot…
  • Stabilizing Motion with a shot…
    Posted by Matthew Materazzi on February 28, 2007 at 9:20 pm
    Hey gang. The shot that needs to be stabilized is a shot that has a close-up of a face, then slowly zooms out to reveal a bunch of people. The problem is that though the camera was on a tripod when this was taped, you can still see a noticable shaky movment as it zooms out. I’ve read the directions, help books, etc.. on motion stabilizing, but it’s no good. The shot keeps on going right up and out of the frame. It is following the track all right, but the problem is that the zooming back makes the entire scene move up and to the left. Any help would be appreciated.
    Matt
    Jesus is Lord
    Matthew Materazzi replied 19 years, 6 months ago 2 Members · 2 Replies
  • Kevin Camp
    February 28, 2007 at 10:01 pm
    try to take your stablized footage comp and make it large enough to so the footage stays with in the frame. then create a new comp with the frame size of your footage (and frame rate, etc), bring in your stablized footage comp and key frame position to keep it in frame. just enough keys to keep the pan (or tilt) movement of the camera, not the shake.
  • Matthew Materazzi
    March 1, 2007 at 1:29 am
    Thanks a lot. That works 🙂
    I appreciate it
    Jesus is Lord
