Activity Forums Adobe After Effects Stabilizing motion in AE
  • Stabilizing motion in AE
    Posted by Christopher Mcnamara on March 31, 2009 at 2:27 am
    Dear folks,
    Using AfterEffects I’m trying to smooth out some aerial video images that I have. I’m having no problem with the position setting but when I also try to include the rotation (badly needed because the horizontal shake is quite pronounced) I get the image rotating pretty dramatically (sometimes as much as 90 degrees). I think I’m doing something wrong. Going to the rotation setting in the layer reveals a lot of keyframes.
    How can I correct for this so that I can get a useable image. I think the shake is slight enough that I should be able to do it effectively.
    All help would be greatly appreciated.
    cheers
    Chris
    Bartek Skorupa replied 17 years, 6 months ago 2 Members · 1 Reply
  • Bartek Skorupa
    March 31, 2009 at 7:14 am
    If you feel that rotation needs to be stabilised as well, I would suggest as follows:
    1. Stabilise the rotation.
    2. Add “null” to your comp.
    3. Parent your stabilised footage to the “null”
    4. Recreate the rotation using “null”. Try to use just a few keyframes. Sometimes only two is enough. I would suggest one at the beginning, one at the end, and then tweak the rotation in between if needed.
    Bartek Skorupa
    Warszawa, Poland
